This command can be used to display an MLD-related configuration and group information, per VLAN or for the switch as a whole.
| name | Specifies a VLAN name. |
N/A.
If you do not specify a VLAN, the command displays the switch configuration.
The following is sample output from the show mld command:
# show mld VLAN IP Address Flags nLRMA nLeMA MLDver Default ::/0 ---iz- 0 0 0 v1 ::/0 U--iz- 0 5 0 Flags: (f) Forwarding Enabled, (g) Fast-learning on, (i) MLD Enabled, (m) Multicast Forwarding Enabled, (U) Interface Up, (z) MLD Snooping Enabled. (nLeMA) Number of Learned Multicast Addresses (nLRMA) Number of Locally Registered Multicast Addresses
The following command displays the MLD configuration for VLAN v1:
# show mld v1 Query Interval : 125 sec Max Response Time : 10 sec Last Member Query : 1 sec Robustness : 2 Interface on VLAN v1 is enabled and up. inet6 ::/0 Locally registered multicast addresses: Learned multicast addresses(Last Querier=fe80::204:96ff:fe3a:ce50): ff02::2 ff02::1:ff56:5c2b ff02::1:ff00:2 ff02::1:ff3a:ce50 ff02::1:ff55:5c27 s = static MLD member Flags: IP Fwding NO IPmc Fwding NO MLD YES MLD Ver v0 Snooping YES
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
